i tried to shim again today, the only way i can get it to be completely straight is if i had 5 shims on the front exhaust side mount. It was 2 thick shims and 3 very thin ones, not sure the exact mm. No other shims on the other motor mounts. I think the motor isnt taller but rather more to one side than the other. Not sure if you guys can understand but let me know if running that amount of shims is bad.
