SJ/XPBri
Just SJBri = no more XP
- Northern, NJ
I went out to my hull this morning to drop the motor in- oops forgot to add something to the "To Do List" over the winter. The pics below explain the problem. The motor mount insert with the broken bolt shouldn't be an issue, I'll weld to it and pull it out. The problem is the other pic. It appears that someone allready attempted a repair- It's some kind of insert, the likes of which I have never encountered. It is secured from pulling out of the hull (I have no idea whats holding it in) The problem is, it is extremely loose and wiggles around, and will most likely fail- So the question is, how in the hell do I fix this? I thought about removing it from the hull and trying to glass a new insert in place, but not too sure if it would work.
Thanks,
Bri
Thanks,
Bri
