- sunbury ,ohio
I sucked up my busted FA and scored my cyls . the FA was barely hitting the hull and from the front you could only see a little bit of rubber wearing away from the top of the FA so I was not concerned . I always checked it for tightness , which did me no good . the shiny vertical wear was against the hull side , the huge tear was in the rear of the FA and could not be seen so it continiously sheared against itself '' 210 psi compression viborates a lot '' ,this shearing action broke little alluminum wires from the torn part of the FA and in they went ... and down went compression to 175 psi. ............. $411 later Im back up an runnin an ready to rip .All's well ! Ignore the prop pic .
