Just looking for some advice or opinions on this because I really can't see anything wrong with the machine, its just running poorly and I'm stumped.
last winter I rebuilt the top end, had the carb rebuilt by Rich at WFO, and put in a stock waterbox. It ran better than ever all summer, topped out right around 40ish. sometime a couple weeks ago I filled the gas tank a little to much I guess and after it sat for 3 days I come back and the engine is flooded with fuel almost up the the carburetor. I emptied the engine using that quick release drain plug on the bottom that I had thought was useless until now.
once it was empty I spent a couple minutes trying to start it, it would usually fire right away but it was giving me some trouble. I finally got it running (poorly) and a black liquid was coming out the exhaust. I ran it on the trailer with the hose hooked up for about 5 minutes until I had flushed out all the black liquid.
Got the ski in the water and it ran fine for about a half hour until it started to slow down to about 15-20 mph at full throttle. Barely keeping it running I limped home. Once on the dock it seemed to run fine so I left it. Took it out a few days later and it ran fine at first but after a while it started to run very weak again, this time until the point where I needed to be towed in. At the dock it started up and ran fine on the hose.
I haven't put it in the water since. Compression is good, carb is freshly rebuilt, has spark in both cylinders, fuel is fresh. I'm really stumped on this one
Any advice would really be appreciated.
