Etheraldreamer
Be there and be square.
- Spring Hill, FL
Ok after much reading im am officially 100% confused. the problem is the midshaft and bearing housing. i realize the SN and the RN are different. Is it just the housing that is different or the length of the midshaft as well?
the problem is, i have a WCF topdeck conversion to slap together when i get home, and it has a xft bulkhead going in it. Now if its just the bearing housing thats different i assume i use a RN housing since its going on the new bulkhead? but if its a length difference then i will need to use a SN housing and shaft because the bottom deck is from a SN and so the motor mounts and everything will be the same as it?
also to further complicate matters i have ADA billet drive couplers and have heard that they only thread on to the RN midshaft? theres a difference in threads too!?
wtf.
help me out guys.
wtf.
help me out guys.
