I was told ny people here that the bulkhead won't accept the larger bearing housing, but the mid shaft off of a '93 SN does have the larger threads as a RN does.
you need the small bearing midshaft mount.the threads for coupler are also smaller on older shaft.
but you can run a new style shaft if you get matching coupler for it.
all other dimensions are identical.
