Other Mid-hull bilge location
The Superfreak hulls are so tight and a dry ride. I never used my pump, ever!
I've lost my ski upside down for over a min.... Fired right up. Seen chris do the same thing.....
Tem builds a very tight hull, never seen a hull stay so dry..
Also the freaks are so light when upside down the scupper let's very little water in.
I rode a freak in the surf for 6 months!
That pump will be fine, you only want one to bullsh@t sitting in the water when your scupper leaks.
Good to know. :biggrin:
Pablo
sqeez bth levrs & lean bk
georgia
Instead of a basket strainer on the bottom it has an inlet tube. It is meant to install thru the side of a baitwell or cooler but i am thinking you could connect a short hose with a siphon pickup and it will work just as well. You could then remote mount the pump anywhere.
. That is actually s cool idea. I've sold everyone of my stock siphon setups. I'm gonna run the mid-hull location for a while but will def think about that idea. good thinking.
steve-uk
Manners cost nothing
Barrie - ontario
i used to run a pump there and one under the midshaft ... worked great, i made a bracket that came off the battery tray to hold the mid hull bilge pump
