Can I use micro balloons in epoxy? I see they make all these goofy filler additives, but aren't they essentially the same as mixing micro balloons in?
i wouldnt alter the ratio, not a good idea.
Just my experience.... They really thin the mix. Just my .02
I'm not quite sure I understand what you mean by "thin the mix" - micro balloons are a thickening filler. If the mix doesn't thicken up then you haven't used enough filler. It's amazing how much you need to put in - the first few scoops just seem to disappear as you mix them in.
Epoxy is an exothermic reaction (gives off heat as it cures). Funny thing about epoxy though is it will harden at an exponentially quicker rate if that heat is not dissipated. If you were to mix 8oz of resin and hardener and leave it in the cup, within 15 minutes or so it will begin to gel. AT that point the epoxy itself is getting warm and then 2 minutes after the gelling point (with a full cup) it will be smoking and hard as a rock.
This does not happen when epoxy is applied to a surface or used to wet out cloth. This is because the epoxy is in a thin layer and whatever it is applied to acts as a large heatsink, keeping the epoxy from heating too quickly.
The same thing happens with micro-balloons, you are adding a large amount of material that acts as a heatsink to keep the epoxy cool. It will still harden, it just takes longer. Basic chemistry....
should i add filler to epoxy my battery tray insert back in that keeps ripping out?
Fillers are to thicken the epoxy so it doesn't run - they don't add any strength. In fact, fillers designed to be sanded do the opposite. So, if your insert fits in there tight then you probably don't need a filler. If there is any kind of gap to fill, however, then I would use something like cabosil to make a thick paste which is very strong.
