Michigan Superjet repair ??
Anybody in the Michigan - Northern Ohio area that is knowledgeable with Superjet repair. Pretty sure that I need a rebuild and I am not a mechanic (just a water shmuck who loves to ride). Would like to find someone knowledgeable who would like to take on the project . Could take it to water craft dealer but would rather deal/ PAY someone who has hands on experience with our machines. 1994 - 701 bored out to 719. Did a compression check with a cheap tester last Fall and read 110 psi in front and 120 psi in the back . Ski runs excellent then will start to cut out and bog/misfire for quite a while and all of a sudden will start to run excellent again . Was planning on putting a new e box in to see if that helps to eliminate the problem . I would also like to rebuild the carb while doing said repair /rebuild at the same time . If anybody is interested or has any suggestions , please let me know. Thank You .
SuperHumanJetski
keep it simple
I work on superjets and a/m skis only in my free time. At that bore I don't know if you could go any bigger with the sleeves on a 61x cylinder. Call me sometime 6169153447
Sent from my SM-G965U using Tapatalk
SuperHumanJetski
keep it simple
Btw most of the time I see a ski with those symptoms it's usually something as simple as the ignition boots over the spark plugs, but wouldnt know for sure without seeing it
