Nuther Superjet...but this one will be cool. :sneaky: :biggrin:
Anyways, I started tear down in December. It took a while to strip the hull, sand it, and defoam.
For the defoam, I opened up the back purdy good and let loose with a wire wheel.
I reinforced back there while I was at it.
Also, all intrusions into the rear were sealed off with 5200.
I tore out my old one way valve (too small) and stuck a big 2 inch valve and pipe in there.
I refoamed with 3lb foam.
After that, the hull weighed in at 120lbs.
