Ok finally some PROGRESS:arms:
I put my 28cc domes back in but did not check the compression yet.. i will soon tho... Im getting a brand new Snap On gauge. I really think something was wrong with the gauge i used, and i didnt use the same gauge to check the comp on both sizes.. so i want to get a good gauge and see.
Anyways, i kept messing with the carb... First thing, as someone said here, the return on the FS is drilled out, so i wasnt using a restrictor in the return and thats one of the problems i had as there was no pressure in the carb. So i put a 60 jet in the return line, and that made things a lot better.
My jetting is way far from anyone recommended (135, 125).. Now i have a 150 main, 145 low and a 95 spring with a 2.3 NS and the ski RIPS compared to before, and feels like theres more power to be unleashed, but i stopped here till i check my compression... i want to get my compression to around 195 then do the fine tuning. Im sure i need to change some more jets around.
Now how do i know if im good where im at or need to change the jets?
When i spoke to Ed Barzina he told me to use a 147.5 to 155 main, so i went in between and just threw in a 150 main.
How do i know if i need a bigger or smaller main?
On the low screw setting.. Does anything over 1.5 turns out mean that the jet is too small?
Thats all Folks.. ill post when i check my compression.
Thanx for all the help fellaz
Zane...
