Lowered pole bracket question.
Crab
thanks darin...noswad!
Seattle
Will a lowered bracket work with the stock hood on a 98 SJ, I have a cracked stock one and will be replacing it this winter with something. And is it true, you loose the pole prop up when going to the lowered style? Any ideas for cheap and easy stock hood handholds?
You can use a lowered bracket with the stock hood.
You will most likely loose the holdup for the pole.
Make your own handholds.
oxnard111
Creative RE Purchasing
Yes the lowered pole bracket will work with a stock hood
Most brands ditch the pole prop thingy, but I know the blowsion brand bracket does not.
