Super Jet Lowered nose piece
Yami-Rider
TigerCraft FV-PRO
Texoma
1 or 2 screws threw the top front and 2 screws at the back is how I've always mounted them.
It could be done without screws at the front, but it would be a lot more work.
I think the older Waterdawg nosepiece's used a bracket that attached similar to the stock nosepiece (see pic). I've found a few screws work best though.
i just used the 2 coarse thread screws and put a bead of silicone around the rest and it holds great. do not use 5200, it will be impossible to remove. this is the way that tomski recommended. i made a bracket like the wdk one above but every couple months the bond would fail and the bracket would fly off.
Pa
I riveted an aluminum tab to the ski for the nose piece to sit under right at the center. Worked great.
