Looking at 90 SN 701 conversion
Hi all,
Wondering your thoughts - looking to see what you’d pay. Would be in the Midwest market and needs to be completely put together also but everything is there;
*61x 701 engine, complete, with carb, full electrics, exhaust, starter, etc.
*1990 Hull, hood, and RN Handle pole. Fresh white paint. Handle pole has been shortened, and will need the base epoxied, and riveted back on.
*stock Steering, with RN pole pad. You WILL need handle bars
*Stock SN front nose piece with gas cap door in good shape.
*Hull has just had all foam removed, and NEW foam installed, hull all sealed, and glassed (reinforced). Ready for assembly.
*Complete pump assembly, wear ring, pump gasket, exit / steer nozzle, and Solas stainless impeller.
*Midshaft assembly with coupler, and rubber damper.
*PJS Aftermarket performance ride plates, and New Jetlyne open type deep scoop grate.
*Round Nose aluminum Water box, with larger RN exh hoses as well for hull, and engine.
*All 4 engine mounts, and hardware.
*Steer cable
*New hood Seal.
