masterblaster
X-H2
I have a setup thats using a rad 5 mill billet long rod crank with a spacer. Are their cylinders out there that can run this crank without a spacer. I have used it in the past with a enhancer at 25 static,she gets pretty hot in the upper revs with only 4 deg retard at 21. With the longer dwell time at tdc what is the max advance it could handle with a advent or TL if the final timing got as low as 14.
What does a long rod setup do with the power curve compared to a short rod assuming everything else is the same,with ign porting and such
