N3vrSat1sfied
Military Member
- Fort Worth, TX
You went with riser bars?
Geez dude. You didn't waste any time installing that poop.They came in a good deal from @Lumpy.
Josh block runs em on his sj so thought I could try em
Done, think I'll run Lites and Limited locally this season
I'm in the IJSBA region 5, or what was region 5, don't know if they call it that now.I don't normally like to show my greenhorn side but I have to ask.
I can't even find people to ride with locally let alone race lol.
How do you find these people to ride with lol.
Look really good. I like how you hid the reg numbers in there.
Thanks, I'm not sure how the police will feel about them but I normally ride from base so they really cant do much more unless they stop me in the water. All three of my skis reg numbers are displayed but all incorrectly in someway lol. Size is wrong, and reg sticker is hidden underneath poles.
You steal @SpaceCowboy 's shoes?Thanks, I'm not sure how the police will feel about them but I normally ride from base so they really cant do much more unless they stop me in the water. All three of my skis reg numbers are displayed but all incorrectly in someway lol. Size is wrong, and reg sticker is hidden underneath poles.
Lol, I think michelle had em before Luke had em.
Really your only option is to test and cut if needed. The formula depends on your height, arm length, riding stance and where the centerline of your handlebars ends up. If you end up getting one, a lowered pole bracket can change everything as well. It's impossible to say what length will end up being ideal for you.Anybody have sj pole length recommendations? I was at 39" from pole bolt to bars. I'm at 40" right now, shortest I can go without cutting tubes.
Did you get your spring situation figured out? I'm running into something similar with my RRP lightweight pole and working on a couple ideas to keep the small end of the spring from potentially popping out. It looks like a big oversight on RRP's part. They really should have left more aluminum for the spring. Strength shouldn't be sacrificed for weight.
Edit: Just saw above that you went with the stock spring.
But can you handle the Canadian beer?Ready to ride. Probably head out one day after work this week.
Sent from my SM-G900W8 using Tapatalk
