SXR leaking base gasket?
idaho
Just looking for some input on base gaskets leaking, my sxr is an 09, ada head, ported, wetpipe a mild build. This weekend I noticed a little leakage at the rear of the base gasket, rode 3 days probably 15 gals. of fuel, and checked it last night and it is now leaking a lot worse.
Cannibal
Tasty Human
Summit Lake, WA
Don't ride it until you get it fixed.
Best case scenario, it only leaks out under pressure.
Worst case scenario, it leaks out under pressure and is leaking air in under suction causing a lean condition that toasts your piston and dome.
You will know when you pull it apart.
