- North Riverside, Illinois
Hull is pretty barebones but some accoutrements are included. Gelcoat has some spidering and there are the usual dings and such but nothing structural. Hull is easy to build. No grinding of pump and only minor shimming required. Turf isnt pretty but well padded and I only added the footstrap for carving waves. Has deep, built in front foothold. Inserts facilitate stock fuel tank and battery locations. I had a JetManiac waterbox installed and everything fit super easy with a B-pipe. Hull stays dry and hood seal is in great condition. I've added some rail mounted fins to help carve harder turns.
Included:
Cold Fusion hood hooks.
Hood latch with Blowsion hook.
Aluminum pump shoe.
Scupper in pump area under tray
Extended ride plate/back end.
New replacement sidewells with some hardware including mounts.
Footholds that bolt onto mounts. (I never used these and don't have all the hardware)
Some other miscellaneous footholds.
$1900
Located in Northern Illinois
Sent from my SM-G973F using Tapatalk
Included:
Aluminum pump shoe.
$1900
