SX/SXi/SXi Pro kawi to yamaha pole Conversion ?
Hey Guy's, I'm wondering what has to be done to convert a 750 SX to accept a RN pole and steering? ( I searched and couldn't find much)
Thanks in advance,
Travis
djkorn1
kidkornfilms
Cleveland Ohio
New bushings from Blowsion and I think a cable holder from blowsion (tell em what your doing)...then you'll have to grind out a small section of the yamaha pole so the steering cable can poke through the left side instead of the right. This is a GREAT conversion. Yamaha steering rules. (cut two inches off of the pole on the bottom while your at it) You will love it.
btw...both parts are cheap.
Tyler Zane
Open Your Eyes
New bushings from Blowsion and I think a cable holder from blowsion (tell em what your doing)...then you'll have to grind out a small section of the yamaha pole so the steering cable can poke through the left side instead of the right. This is a GREAT conversion. Yamaha rules. (cut two inches off of the pole on the bottom while your at it) You will love it.
fixed :biggrin:
