- South Denmark
Hi all ( following Thread will be updatet during the winter )
I have had my SX-R 2006 for almost 5 years now and i love it. Everyone i talked to tell me that the ski is a lot funnier with Head And Pipe.
I am now building my ski with several mods. Hope you comment it and will follow the build up.
The plan is following ( and all the parts is bourght:
Hull:
Weight reduction ( startet and on 21lbs )
Carbon reinforced hull
Blowsion 2 Tubbies
Umi steering
hand warmers
Blowsion foothuls
Bilge pump
Several blowsion fittings
Drain plug
Shread Master Carbon Rideplate
TBM Grate
SOLAS impeller
Bored Nozzle
Bored Exit Nozzle
Hydroturf
Engine:
Stock Bore
Stock Crank
Stock Pistons
R&D TOP END 165 PSI
Carb with no choker
Primer
R&D filter kit
Facotry B-pipe (wet ) And manifold
Water steering on exhaust
Protec Ignition
6' Timing advance
Polished carb intake
Now the pictures of the build:
Hull:
Blowsion 2 Tubbies
Umi steering
hand warmers
Blowsion foothuls
Bilge pump
Drain plug
TBM Grate
SOLAS impeller
Bored Nozzle
Bored Exit Nozzle
Hydroturf
Engine:
Stock Bore
Stock Crank
Stock Pistons
R&D TOP END 165 PSI
Carb with no choker
Primer
R&D filter kit
Protec Ignition
6' Timing advance
![IMG_0412[1].jpg IMG_0412[1].jpg](https://www.x-h2o.com/data/attachments/125/125776-e0bafb6ab8e53829b95f2c1f5f5d5320.jpg)
![IMG_0431[1].jpg IMG_0431[1].jpg](https://www.x-h2o.com/data/attachments/125/125777-ea904c49030938e832aa7a2bb6f8c864.jpg)
![IMG_0430[1].jpg IMG_0430[1].jpg](https://www.x-h2o.com/data/attachments/125/125778-2199fa3d6781a01cdbffecb89ccd4844.jpg)
![IMG_0432[1].jpg IMG_0432[1].jpg](https://www.x-h2o.com/data/attachments/125/125779-290627a854fb33fb3140dd5584162eae.jpg)
![IMG_0440[1].jpg IMG_0440[1].jpg](https://www.x-h2o.com/data/attachments/125/125780-66f75b720299ddcf9c22d3dfda98b93b.jpg)
![IMG_0435[1].jpg IMG_0435[1].jpg](https://www.x-h2o.com/data/attachments/125/125781-e3a6268c360a16fe887ae7fb7a237c73.jpg)
