just another square
brentR
way fast whitey
Toronto
that stock turf aint no thang , any suggestions.. ??:aargh4:
first mod - footholds
plan - usual freestyle stuff with my b1 motor that im gonna port\bore.
brentR
way fast whitey
Toronto
im defiantly gonna do the home depot scupper but if ur willin to give me the money for the top deck ill write u up an 'i owe you' :D
Rickster said:
Rome was not built in a day, and neither does your Sjneed to be....:cool2:
Good luck on the project, I wil follow it closely.
looks like a good boat to start a build with.
dont listen to risk and his rome wasnt built in a day theory. hes only saying that because he takes forever to even cut the top deck off the square.:biggrin:
Frosty
New York Crew
Western New York
I used one of these to get most everything scraped off the flat surfaces, then used 3M adhesive remover to get the risidual glue off. worked great for me...
Snap-on
Scraper, Long, Razor Blade, 13
Stock#: MS1300
adhesive remover:
Grainger Item # 3KB83
Price (ea.) $13.08
Brand 3M
Mfr. Model # 6041
Ship Qty. 1
Sell Qty. (Will-Call) 1
Ship Weight (lbs.) 1.5
Usually Ships Today
Catalog Page No. 2880
brentR
way fast whitey
Toronto
ok i started doing my footholds, now on the right side it seems the foothold is hititing the exhaust pipe... is that because I put them too far forward? or do i have to do somethin about the pipe?
i wasnt sure about placement so I put the holds so they start at the flat part of the tray.. about 6-7" from the back of the tray
Hogggman
Stock Sucks
White Lake MI
You should be able to slide it back enough to just clear the exhaust. If not cut the hole slightly larger in the back to do it. If you look at your footholds the exhaust side should have a slight angle in the front to clear.
looks like you put them to far forward...I think mine are only like 4-5 inches from the back of the tray if that, mind you mine is a roundnose. Just keep cutting them back until they fit. Thats the good thing about glass you can always fix what you need to. Heres a pic to show you where mine sit.
brentR
way fast whitey
Toronto
yeah i fixed them, just cut some more material out.. and good lord is my tray ever wavey haha..
i checked my foam and its all dry .... woot... just gotta cut other hole and install and foam behind em... and im tempted to do the home depot scupper
brentR
way fast whitey
Toronto
:headbang: :headbang:
and for ****s n giggle i got my new HT cover
brentR
way fast whitey
Toronto
sorry ive been procrastinating... and dumping all my money into my new car :cool2:
heres how she sits, holds waiting to be glasses in and foamed... gonna use great stuff to foam em...
and my new stand , gotta love having a bro as a welder... hes making my roundnose conversion bracket now
