JS440 701 conversion waterbox issue
Hello everyone I have a Kawasaki 440 with a Yamaha 701 62t conversion with a B-pipe I have installed everything and the jet ski does turn on but at the moment I been trying for one month to figure out what waterbox I can use as I only have a very small space I tried to use the JS OEM waterbox doesn't fit. I tried to use sea doo 587 waterbox and it doesn't fit can I straight pipe my jet ski I know it will be crazy loud but I'm okay with that but would I risk getting water back to the engine?
Can I use a resonator or would I still risk getting water back to the engine
I'm not sure what to do at the moment if anyone has does this conversion and figure out the right waterbox let me know thanks.
I have a stock superjet water box in mine. However I am using the stock exhaust system. I also had to move to internally filling my fuel tank.
How does the b pipe fit. That ski is going to rip! I can’t wait to get one on mine. What pump are you using?
I'm not sure if the super jet waterbox will fit with the b-pipe I have deleted the fuel fill from the front still can't fit anything
There is a solution, there is a company somewhere out there remaking the Pjs style resonators that wrap around the tank and install under the tray, that syatem would be reasonably quiet and should fit.
possibly ..here is one for sale http://www.pwctoday.com/showthread.php?t=498513
there is also a resonator L shaped that was made by bad bones i think kinda rare
Bad bones were U shaped I have what's left of one in my 300SX, I also had one of the L shaped ones, I believe they were used in the 750SX and made by jetcraft and MMF made resonators also , I have the vee type in the x2 I am building as well as an oval type undrneath the footwell on the right side..
Pure resonator madness going on here , yes they are mounted behind the engine and then it makes a 90 out of those dual resonator sand dumps into yep you guessed it another resonator under the footwell.
dfw
They needed every one of them! I wish someone could convince owners of those big offshore boats to run mufflers.
