Other Jettribe RS-15 Leg Guards
Unlike the hard and heavy leg guards used by many runabout racers today, Jettrib’e innovative 2011 Leg Deflectors offer the very best in leg protection while maintaining flexibility, durability, and weight savings. Infused with years of technology, Jettribe’s dual-panel leg guards are made with two corrugated-honeycomb poly carbonate cells laminated together covering both the front and outside of the shin. Then, each protective cell is wrapped in ballistic nylon, four layers of protective compression-molded EVA open-cell foam, and an air mesh layer over the 6 mm molded neoprene outer covering. Simply put, Jettribe’s 2011 Leg Deflectors can absorb impact and redistribute the force throughout.
Web: jettribe.com Leg_guard_specs_large_JTG # 091220.jpg
SUPERJET-113
GASKETS FOR CHAMP BRAP!
This is a good thing if your a racer of a runabout or need lower leg protection..
I was at a race around 15 years ago and saw a guy get T-boned and his leg was right in the middle. When they hauled him back to shore on the water stretcher the only thing that was holding his leg on was his wetsuit! If he would of had some protection he might of not lost his leg.
