Well.. most the time when adding a pipe to any ski it will need to be jetted... your going to have to look at your carb, if it's a round fuel pump chances are you will not be able to turn the hi screw out enough for the demands of a pipe.. if by chance you have a rectangular fuel pump and a newer sbn carb, you would be able to open it up, remove jets, see what size your at now, then probably bump up the main jet a cpl of sizes, and probably leave the low circuit alone.. but I can't give you the advice you need if you don't tell me exactly what carb you have.. most 300's come with the older 34bn carb, but it's possible someone may have upgraded yours or your model year is new enough that you'd have an sbn carb. . but only you can tell me what you have...
