SXR Jetinetics flywheel
djkorn1
kidkornfilms
Cleveland Ohio
I think they are all about the same. I run a Vilder with no magnets (but did have one crack). It will make a HUGE difference on low end hit on a Kawi.
Octane_114
LeT tHe gOOd tImEs RoLL
Charleston S.C.
I run tbm. kawasaki book say 94ft lbs. i did 720inch lbs which is 60ft lbs and I used red lock tight. tbm also wants you to check it after so many hours of use.
Shonuff
I've got the glow
Memphis
I've got Jetinetics on one, TBM on the other.
The TBM is the prettiest but wouldn't run with my 2003 electrics.
TBM is 65 ftlbs I use red lock tight. I also have found after a season of riding that a torque check will move the bolt so I pull the bolt annually and re-torque with fresh lock tight. It's probably overkill but I don't like to break down in season
I felt a difference with the flywheel. Also found I had to bump up the idle as the engine would stall on off throttle landings.
