SXIPro
JM781 Big Bore
- Here on the 'X' mostly
So if any of you have been following the drama, I had a no start then a no spark condition(actually it only sparked when I let off the start button) that after a lot of help from folks here I diagnosed as a bad pulser coil.
I pulled the flywheel cover and the inside of it was covered with premix and metal shavings. Pulled the flywheel a minute ago and it is far worse than I would have guessed. The stator was not even connected to the engine, it came out with the flywheel. I found one full stator screw and one half of one. So, yeah, I've got a broken screw in the engine. Oh and the flywheel magnet is toast as well. Most of the chunks of metal come from the stator, as you can tell by the missing pieces on the stator plate. The good news is my diagnosis was right since the red white wire was snapped off the pulser coil.
Could all of this goo possibly come from just a leaky crank seal?? Oh, and when the time comes, how do I know the correct placement of the stator since I don't know where the original was since it was flopping in the breeze?
