300/440/550 Is tuning a BN carb like tuning a SBN carb?
Polish jet pilot
4aces4aces4aces4aces4aces
Warsaw, Poland
More or less. You have 3 screws. Remember however that SBN has interchangeable jets. BN does not have this option. If look on the side close to the screws of the carb you will see "H", "L" and "P". This are for high, low and pilot just
dont turn more than 1/4 turn at a time...
Have fun :)
To answer your question they tune different than a SBN for the set up but for the BN, The Pilot adjsuter is for the idel only and then the low speed adjuster is for up to 1/4 - 1/2 throttle and then the main jet which I drill out to .040 is for the 1/2 -3/4 and then the high speed adjuster is for the 3/4 to full throttle... Always start with the pilot and go up from there as each circuit still feeds the carb so going the other way will effect the results...
dirkdiggler
WI
how many turns out on the pilot adjuster is a good place to start?
Does anyone know what size Needle/seat & spring came stock on a 1990 550sx??
