- uk
Hi guys,
i'm a bit confused by the head i took off my 61x egine.... to give you an idea of engine spec, its got factory pipe, 48mm ATP freestyle carb, carbon reeds & side exhaust (and the westcoast head). this motor was in need of a rebuild as it had scored pistons.
i've had the cylinders ported & re-bored to 82.5mm and now i'm confuse with the head.
its a westcoast (non girdled) head with changable domes and has 28cc domes fitted. this seems like it would hike the compression up well over the reccomended 180psi for regular fuel?
also, am i right in saying this head should use o-rings? if so mine was used with a head gasket..... i did think the domes look like they have been machined to accept a head gasket, they seem to have an extra ridge/cut in them on the cylinder side?
i think i am going to buy an ATP girdled head anyways, but is this head safe to use? could it be part of the reason it blew the head gasket & scored a piston?
any help would be great.
cheers
john
cheers
john
