Is this good foam to use?
Will that Great stuff from HD deteriote when in contact with epoxy? Was thinking bout scupper as well while the hull is cut up.
WaveDemon
Not Dead - Notable Member
Hell, Florida
the problem I see with great stuff is it's not very ridged and a lot of the strength of a foot hold comes from the surrounding foam.
depends on how you do your install.......if you hog out the whole back channel, you might not want to use it...
if you grind the foam out to shape and just use a little bit of greatstuff to fill the void..I say go for it.....
I filled a little hole in my square tray with that stuff a couple of years ago...it formed ROCK HARD!
