Correct me if I'm wrong...leaking N&S will cause super rich scenario (dribbling fuel and a stumbling engine) versus lean.Needles are probably worn. Replace them.
I would check them...... My first coil started going out at about that age. 3 years. Just need to rule it out.I didn't check the plug wires other than verifying I had spark on both. Coil was a refreshed one from JSS with new wires 2-3 seasons ago.
glad you figured it out, I can't sleep normal until my ski mystery is solved.Turned out to be reeds. I had one petal on the front carb that was mildly warped. The rest seemed ok, but these carbon reeds were at least 6 years old and had been changed from one engine to another. I replaced the whole set (VF2's). Fired up and was back to its old self today.
Thanks for input fellas and for the parts @JetManiac.
Those Hobies out there?Might have spoke too soon. Ran great on test run...bout 10". Parked it. Mowed grass and met up with Mcdog. It started acting up about 15-20" into riding. Leaned out again on front. Checked plugs/spark. Initially only had one side sparking. Checked again and it was on both. Plugs are fresh. Only air leak could be front crank seal. Gonna pull tank, FW cover and FW to check, but highly doubt it. Leaning towards a failing coil now. It's 3-4 seasons old on total loss duty. Will see. It runs well at times so crossing fingers for easy fix with new OCD coil. In any case, was nice to get some tray time in.
Contemplating life and backflips with a brew...![]()
Yep and you'll know if it doesnt follow the carb. Is your pulse line Y'd or does each carb have one?Good idea. I'll flip carbs around and see what happens. Carbs checked out fine with pop off pressure and internals clean. I'm assuming air leak somewhere...
