cmg
Proud Dad!!
- Olympia, WA
re-installing my drive line after paint on the ski. Noticed when I was shimming the engine that there was a much larger then normal gap between the couplers (definately out of the 2-4mm) tolerance.
Pulled the midshaft housing back off and realized the shaft has been pushed back through the housing quite a bit. If I get the shaft pressed back to tolerance (approx. 3/4 inch) will all be OK? Is there potentail damage related to the shaft being forced back or having it pressed back forward?
