Philip Clemmons
Owner, P&P Performance
- Richmond, Va
What should it be?
Mine seems way too tight!
This is not a hub issue, but actual blade diameter or liner diameter......................
There is around .0035 to .004" clearance. Just the little bit of torque from tightening the pump causes it bind against the liner. This is with no nozzle or midshaft-nothing is hitting anywhere except the feet of the wear ring to the hull. If I leave them loose it spins freely, but tightening them up distorts the ring enough that it rubs. I though most oem "new" specs were around .008-.012. I know the mag is likely set up tighter for performance, but there has to be some room for bearing runout, etc..................
Experimenting with shims on the feet now to see if that helps.; Looks like the hull is not 100% flat where the feet go.................................
