- no where near
Hi everyone. I am recently a new owner of a 1990 superjet. At the start up it would caveat some before it would catch and run fine. So I decided to replace the large seal that is in-between the impeller pump and the hull. While I have everything apart I decided as well to replace the seals and bearing for the impeller. This is where I have run into problems. One of the previous owners installed a Skak Trak 9-17 and I can’t seem to get it off to get to the bearing. To the best of my knowledge it is reverse thread so I know I am not going the wrong way. I do have the tool to hold the end of the drive shaft in the vise. I have tried heat, impact wrench, and soaking the threads for a day to see if I could get it to turn but I haven’t had any luck. Is there something I am missing? Any advice would be greatly appreciated.
Thanks,
Kevin
Thanks,
Kevin
