I have a stock SXR 800 in a Q8 Sky. I recently had JSS install longer coil wires and I got VForce 2 Reeds in addition to a bored intake manifold. The first day out on the water after the mods the ski ran well. Powerful, but it stalled every once in awhile so I decided to adjust the carb screws. The ski got worse. And after messing with it a few times it would barely run or start.
So I sent my carbs to Art Gomez in an attempt to fix the issue since I thought I had something floating around in my carbs. Got em back and the ski is even worse; it won't even run on the hose for more than a couple minutes (if that).
Symptoms:
-running it makes it stall and it will not start back up. (as if it was flooding)
-fuel was not coming out of the carb holes when i tried to restart it.
-I let it sit for 10+ minutes and it started back up.
-however, throttle makes it stall, so i can only let it idle.
-the moment i give it throttle, it dies.
-i let it idle for 5-10 minutes and it sounded good, then it suddenly started to stall again and it died. throttle was never squeezed and adjusting the idle screw changed nothing when it was running.
Mods:
-EME Q8 Sky
-Vforce 2 Reeds
-bored intake manifold
-OEM coil w/ jss wires
-wetpipe
-skat impeller
-jetting: 147.5 and 77.5
-carb screws both at 1 turn out, because it seemed to run better on the hose like that
I'm thinking it's running rich or the coil is bad. Maybe the reeds broke somehow? Like I said I'm stumped. I need help.
Symptoms:
Mods:
-EME Q8 Sky
-Vforce 2 Reeds
-wetpipe
-skat impeller
