If You Think Pole Breathers Are Enough.....
Stockton
Nice test data.. pretty cool. So I have rrp poll tubes and 2 hood breathers tubes just as large. Was gonna say I am good but my engine is larger so I guess I'll have to do my own test.. thanks for posting :)
So measured mine and it came in at .25 inh20
When I did the finger test, hood open enough for finger and 3/4 inch bilge hose venting back thru bilge pump it only lightly squished on my finger.. So it needed more so I added 2 more 2 inch tubes.
Thnx mikesx and Jr. For the gauge posts
Just to throw another wrench in the works.... The breather tubes like RRP pole tubes are corrugated on inside and outside. This alone cuts down on the airflow a given breather can flow. The corrugations on the inside of the breather cause the air to tumble on to itself. Only breather tubes I have seen with smooth interior are the ones from blowsion however they are no where near 2.5" like RRP or the like.
Those have helped me out a lot vs having open hole into the hull.
Req
SW Tenn
Something to add about the FrogzSkins is that they have some flow resistance compared to an open hole. I added an extra 2.25 hole in the liner to account for flow resistance. I have no idea how much they choke the flow but you can see them suck in a bit if you dont have enough.
Christian_83
Xscream
Denmark
So, i finally got to test this.
Ive been wanting to do it for a few years.
Ski in setup is a NITRO hull, ET1107 Engine, Dual 49 full specs.
RRP pole setup.
So here goes:
First video, NO hood:
Second video, with hood no air vents:
Third video is with hood with 8 x 22mm holes in "hood liner"
last video, is with hood not fully closed:
This is interesting stuff. Surprising that the holes didn't make more of a difference, it looks like the pressure change with the holes is closer to no holes than hood open.
Looks like it takes quite a lot of area to actually make no pressure change.
RRP pole setup.
So here goes:
Are the 8 holes in the “ outside “ of the liner and the 4 holes on the “inside” of the hood liner? Test shows a bit of friction loss I would say.
8 x 22mm holes is equal to 1x 63mm hole, so you are short 24 x 22mm holes on hood outer and 28 x 22mm holes in the liner :p
Join the holes to form slots to gain flow area more effectively in the same space. The other thing is to check clearance between inner lining and outer hood to make sure passage is big enough for air to flow between openings
Here is an altimeter data log from my RC data logger on a 1992 box stock 550sx. This is just for reference only, the stock 550 is not moving anywhere near the amount of air that most of these motors are. If you look at the graph, you will see that the altitude goes from about 0 to 36 feet max (I'm using the altimeter as a pressure gauge, just have to due a little math to back calculate feet of altitude to pressure). This equates to 0.023 psi or 0.637 in H2O. In terms of HP loss it would calculate to a 0.12% HP loss. Looks like the 550 hood flows fairly well.
From graph:
Wide open rpm 6200-6400
Max speed 40.6 mph
Max altitude 36 feet
Inlet water temp 73° F
Head outlet water temp 89°-94° F
Exhaust pipe outlet temp 100°-112° F
When I get time I will put the data logger on my FX1 and see how that hood flows.
  • 550sx With Alt and Temp First pull.pdf
This is such an awesome thread. I have an M1 with a ported 701, PFP, and Dual 46. I have only pole breathers. On top of this, probably 10% of the cross sectional area of said breathers is taken up by cables. Maybe i will take a quick rip with the hood off to see if it makes a difference. Close to shore ofcourse haha. I know this thread is mostly regarding bigger PV motors.
Here are my notes from today's notebook.
The ski only has Pole breathers. Is that enough? When i rev the ski (yes on dry land), the hood does suck down into the seals aggressively. This means there is vacuum inside the bay. I don't know how much, but right now i know that i don't want it.
Lets assume i need equal cross sectional area as the dual 46 carbs, plus 5% for some efficiency loss of whatever orifice(s) and running length is getting the air into the engine bay. That is 3490mm^2.
The pole breathers are equivalent to 3103mm^2. Consider that the cables running through the breathers are equal to 182mm^2. This means the pole breathers are giving me 2921mm^2.
So, 3490-2921‎ = 569... This means i need about 570mm^2 extra cross sectional area into the hood in order to have equal cross sectional area (plus 5%) of the dual 46 carbs.
The solution: Drill (8) 3/8" holes (x2 for In + out) which is equivalent to 570mm^2. I will first tape over the holes, ride it like that, then pull the tape and see if i feel the difference (Being a pessimist, probably not). I calculated the gap that runs under the hood to be roughly 950mm^2 so that shouldn't be a factor.
A bunch of small holes don't flow as much as a single big hole of the same across sectional area. Basically there is more flow in the center of a hole than on the edge.
