i-body carbs
That third link should provide some info on rebuild kits. I don't think SBN and BN parts are interchangeable...but I may be wrong.
I know John @ JSS loves them. Give him a call, I am sure he's got tons of info.
Big Kahuna
Administrator
Tuscaloosa, AL
He installed some, but I dont think he rode with them much... He has since sold his ski.......... no longer rides........
beachedflunkey
wavejunkies
Virginia Beach
That groupk write-up says it has a lot weaker signalling and makes it sound like it's a lot more difficult to tune. I read on pwct it's taper-bored too. I was also led to believe that sbn's and i-body mikuni's were the same other the limited reading i'd found about their external appearances. Thanks guys.
................................ FWIW: another writeup I read stated it was much more forgiving to/ altitude, humidity and temp changes due to the acc/pumps ! I doesent need signal to draw the fuel when its forced in under pressure , was my understanding
RMBC Freeride
Vintage
Pueblo, CO
yeah, but Neil (RMBCFreeride) did this mod before John did, said they worked really well on his SJ...........
Just to clarify... BK is right I have used a couple differnt setups with the I-series carbs. i actually turned John on to the idea.
BUT... He and I have only used the 40I (like what comes on a SXR or a SEA-DOO 720/800).
These are not the same as the 44I that come on the GP800 and some of the bigger seadoos. I have no experience with them on a SJ.
My very best setup with these carbs (40i) was a set that had been modified by Novi: 42mm with their booster venturi. Very snappy on a 701-760, but I would not recommend it for much over 760cc. Very easy to tune and a very strong signal due to the way the I-body throat is shaped. I still have this set but all my motors are too big for them now!
