Will i hair dryer work or, or should i invest in a heat gun?
Also, what do you do at the seams? just keep it as close as you can?
Wheres a good place to buy the contact cement? and is weldwood the "best"?
I still got a ways yo go on my 550 but id like to get everything ready for when i turf atleast.
get a heat gun - dryer does not get hot enough.
starting with your uncut sheet of turf - you should be able to turf your rails with 3 strips of turf cut down the long side of the sheet.
match the seems - you should be able to get very close between the pieces you cut.
I started at the bow eye (I don't have the front bumper) with a piece cut for the notch and centered. glue it down at the bow eye - then using your heat gun, heat one side at a time and attach the top edge of the turf on the top deck. Heat the strip, then "roll" it down over the bond rail. repeat on the other side of the bow eye. Beat it down with a rubber mallet.
It helps to bevel a 45º edge on the bottom side of the turf where it is adjacent to the top deck. Make sense?
Match the pattern of your next piece at the seam. Using a partner - heat the turf and stretch it a few inches (lengthwise) - and that will turf the rest of your rail - all the way around the rear corner.
sorry, I didn't take pictures as I was doing it.
use DAP Weldwood. Buy it at Walmart.
