Surfriding Hx compression help
Hello my name is Brandon and I have a 96 seadoo hx that I am doin some work to and just looking for a bit of advice for dome recommendations. It's still a 720 and the mods so far are: k&n filters, r&d intake manifold, jetenetics light weight charging fkyweel, an factory pipe. I want to stay on pump gas but want the most I can get while staying on it. Just wondering what a good compression range is for this ski.
smoofers
Rockin' the SQUARE!!!!
Granbury, TX
Honestly, you will never make that motor last very long with the factory pipe if you run pump gas.... I know for our sport spec HXs we are limited to ~165psi compression. But, the factory pipe on the 720 is a very sensitive combination and on stock compression I would still recommend that you go higher than 93 octane....
