- Charlotte NC
Did Yamaha make hull hooks with a larger hole, lets say to fit an 8mm bolt?
I built a wdk hull at one point where it was either install ufo mounts or use the lay down wdk mounting pod. I chose the pod. It had 3/8 coarse inserts in it. I spread oem mounts apart, drilled the hole, tighten them down, then bent them back together. Not my favorite work, but I had to do it
Yeah, I've drilled them out before too... not fun at all. Just figured I would check to see if there was another option.
Could you just do the single pin and eyelet thing like tigercraft does?
Or hit up Brian @THRUST he might have a solution
Would something like this work for you? They are currently setup for m6. I can imagine you could easily drill to m8 and use a countersink tool to make them work for your application. These go for $9 a piece.
In stock and ready to ship.
