- Washington
What are the smallest hull hook straps that are made for OEM straps. The one I have now will not work in the hull to fit the power factor water box. Those are the mounts I have to use.. This is Jacks hull and did run PFP before.
Try a blaster battery strap
U need the one with a crimped piece and a hole drilled on that one
Sent from my SAMSUNG-SGH-I337 using Tapatalk
But to be honest in amandas chan we do not have any strap holding her pfp box
It's a tight fit we pinned it under that lip below the hood line
We glued turf to the back and to the top of the box and then glue inch under pad to the bottom and it fits like a glove
Captured end strap would be the way to go there.
Where do you get these types of straps?
I wonder, any guesses?
Well, someone told me that there is this guy on here that sells everyting under the sun for these ski and has the best customer service around, but cant seem to remember his name...
Didn't see them on the master list.
He might know a guy who knows a guy who can get you what you need.....I wonder, any guesses?
