How to shim the jet pump?
Metal4130
Eat, Sleep, Ride, Groove
Chicago
The retard who I bought my superjet from didn't think they needed to put any shims in the jet pump. I have been reading the manual and they say there should be shims on the pump stator where it bolt to the hull. My question is how do I know what shims/how many I need? Is it like shimming an engine?
oxnard111
Creative RE Purchasing
I'm not sure how to answer question on how to verify if you have the proper pump alignment, but I do know that my 97' i bought recently had writing near those two bolts that said how much each side was shimmed. Maybe yours has that also?
Metal4130
Chicago
So really it is different with every ski then. So when I bolt up the midshaft to the hull I should then slide in the jet pump and if there is space between the mounting tab and the hull then I should shim that out.
