mk1
PUDDLE - BLASTER
Dudes , e-box took in some lake water , no spark.... I have replaced coil , new spark plugs , changed cdi unit with a used good one , & starter relay is fine. Still no spark. All that`s left in there is the rectifier/regulator. Going to change that too..! But i have never changed a stator coil. Do i pull the flywheel and just replace old with new , or does it have to be setup/fine tuned etc.. ? Thanks in advance...
