How "Superjet" is your Superjet?
SJBrit
Extraordinary Alien
Bradenton, FL
People always ask me what kind of ski I have, and I say "it used to be a Superjet". That got me thinking about which parts of my ski are original and unmolested. I was a bit shocked at how small the list is, although I know others have shorter lists.
Here are the things on my ski that are exactly as they came from the factory. Starting at the front:
Nose foam
Water box and pipe downstream from there
Throttle cable
Motor mounts
Bed plates
Starter
Hood seal
Midshaft
Driveshaft
Wear ring
I think that's about it. Having bought the ski new I feel rather proud of how little of it is left!
So what about you? How much of your Superjet is still as Yamaha intended it?
JustinB
Proof I has a brain \l/
Oxford, MS
My list on my RN is smaller than yours:
no nose foam
stock waterbox
kawasaki throttle
stock motor mounts
stock bedplates
aftermarket starter
DIY hood seal
stock midshaft
aftermarket driveshaft
unknown wear ring
EDIT: I forgot:
stock start/stop switch
stock pole bolt
but I didnt start with a stock ski like you did; mine was built from an old Wammer hull and leftover parts.
OCD Solutions
Rentz, GA
interesting lists, what about engine cases and starter?
I got so carried away upgrading stuff on my 96 superjet that it looks like a Trinity Matrix now, lol.
Stock Superjet parts left unmodded...or mostly unmodded anyway.
Nose foam,
Fuel tank,
Waterbox,
Long Exhaust Hose
e-box housing,
voltage regulator
Midshaft and coupler,
wear ring,
hood seal,
engine cases, crank, bendix, bedplates,
pole bolt,
steering stop nut,
pump shoe...
Hull
Hood seal
Nose foam
Tank
Cases & Cylinder
Electrical box
Midshaft & Coupler cover
Starter & bendix
Reed cages
Start/stop switch
Waterbox (also mandatory) & all exhaust hoses
Big Kahuna
Administrator
Tuscaloosa, AL
Since I got my first SJ (Later Hull Replacement) the only items that I am still using are:
Bedplates
Battery Cables
Main Exhaust Hose
Bolts
Electrical Box
Everything else has been replaced. I still have my original cylinders, they were ported by TLR in 2003 and Retired in 2007 when my crank let go. Paul resleeved them for me a year or so ago and they sit on a shelf as a backup to his 84mm Cylinders that I am running now.
OCD Solutions
Rentz, GA
I have replaced 95% of the hardware on both my skis with stainless Allen Head bolts.
Between the 2 superjets and parting a couple couches I must have 50 lbs of OEM bolts on the shelf.
