How many screens on stock filter
showmepro1200
ISJWTA Member #007
Oh sorry! I didn't know I was giving advice to the VINTAGE CROWD!
Come on now, Superjets have had dual carbs now for OVER 10 years! ('96)
Look at my sig and av - I have one of both - gotta start somewhere and when you get the 90 for $350 in immaculate untouched condition you just can't pass up the deal :Banane01:
Anyway, back to the question - which is - does removing some of the screens affect the mixture enough to require a richening???
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Not sure on a bone stocker? Why bother if its bone stock? Are you racing in the stock class of some sort? I do this when I rejet carbs and the install pipe, dual cooling, ignition upgrades or when adding other mods...
showmepro1200
ISJWTA Member #007
Totally agree - wasn't trying to go out and race or anything, I had just taken them out thinking it would give the SJ a little more kick out of the water, a cheap trick to get a little more power. When I tried it though, it seemed to stumble a little bit (just slightly), so I put them back in and it reverted back to normal.
Sorry to ask such a 'stupid question'. No big deal.
Btw, there are folks around here that swear by a single carb setup for their purposes.
sea-dude
To Air is Human
I have noticed when I use 3 screens I have to suck way harder, and it kinda hurts my lungs!:439: :439: :smokin: :smokin: Wouldn't this be the same for a motor?
Crab
thanks darin...noswad!
Seattle
Just blow thru them, you will see the diffence as how much air comes out the other side.
sea-dude
To Air is Human
I had 2 stock F/A apart yesterday, the screens line up so close I don't see how it would reduce airflow to remove 2? So I left 3 in one boat and 1 in the other. I guess I should do a plug check?
showmepro1200
ISJWTA Member #007
Wouldn't reduce airflow, it would increase airflow if you remove them. Like I was told though, on a stock machine it's not the big of a difference.
