How many layers of glass
tor*p*do
Squarenose FTW
NW NC
Just got my WaterDawg REVs installed and laid up on layer of 3 inch stips of cloth around the join line.
how many layers of cloth do most of you use?
i plan to use 3 or 4 on the tray and the bottom of the footholds
Thanks!
tor*p*do
Squarenose FTW
NW NC
shoot, I am using 7.5 oz 3 inch strips around the foothold and I have a big sheet of 7.5 oz for the floor.
i guess 2 - layers would be about the same strength
isnt it hard to properly wet out such thich glass sheets?
thanks!
Boris
The Good Old Days
I have no clue how much and glass you should use but I like how you got them to fit. Nice work. :biggthumpup:
I know mine put up a struggle to sit flush.
meatball
User Title Unavailable
Maryland
biax is alot stronger then regular cloth, but in any case I think two layers of the 7.5 would be fine. And no its not that difficult, just takes a 1 1/2 inch paintbrush and a lot of epoxy (as much as required anyways)
Crab
thanks darin...noswad!
Seattle
thanks!
No problem getting it to saturate, it just is harder to get around sharp curves and corners. Its made up of 3 layers of material sewn together, so it is about 3/32-1/8 thick when done.
http://x-h2o.com/showthread.php?t=11193
