How do you remove a Kawi 750 flywheel?
Air Gramps
Air Gramps
Virginia Beach
I removed the flywheel bolt, how do you pull the flywheel.
I can't see getting a claw puller on and no threads for a harmonica puller.
The fly wheel has threads inside ? Is it screwed onto the crank?
i believe youre supposed to thread a bolt into those thread and it pulls the fw off. ive never pulled a 750 fw, so im assuming.... id think your want a washer between the bolt and crank to not mess up the front of the crank. im sure theres a specific tool for it though.
john zigler
wisconsin
you can use a regular 18mm fine thread bolt, or buy a 750 flywheel tool, ( which is really the same thing).
if you get a bolt, just be sure to get a hardend one.
zig
beachedflunkey
wavejunkies
Virginia Beach
I thought I had a hardened one. derm proved that wrong. He ended up splitting the cases and banging the teeth off the flywheel to get the bendix out for his blaster :biggthumpup:
