superjetguy
It's hard to speak without a tongue.
- lake hogan
Let's talk about my setup. I've got a 83mm 61x/62t stock carbs, r&d head ~200psi comp, b pipe, single cooling t'd into both manifold inlets exiting out two holes in the head one to pisser one to top of head pipe, bottom outlet on head pipe goes to the tip of the expansion chamber and t'd to a pisser. The front cylinder is running much more hot than the rear, almost to hot to keep my hand on it for more than a few seconds.. I have double checked my hoses and none are kinked or blocked, what should I do? Oh by the way the fcv isn't hooked up it is only being used to mend the hoses until I can get to the store.
