- Kansas
I've been trying to figure this out and I'm sure this could be the problem. So, the other day I put a b pipe on my 11 superjet, took it out and the first day it seemed to run pretty well. Second day I ended up having to ride fairly slow for around a 10 minute period of time and it seemed the water coming out of the pisser got really hot and the limp mode kicked in. Also i noticed it had a very small hesitation off the line sometimes, and a little bit hard to start once it warmed up. With the stock pipe I could just touch the starter and itd start now it takes a few seconds and pupming the throttle. Could this be running lean on the low side being the engine got that hot? The water I ride in is usually high 70's. The mods i put on at the same time were the b pipe and aftermarket flame arrestors. It has the stock dual 38's, I did not change the pop off spring but did change the high speed jet. I didn't mess with adjusting the needles yet because it was too windy of a day to really be able to mess with it. I would prefer not to cut the temp sensor out until I'm sure of the tuning.
Thanks for any help or suggestions in advance.
