Other Home Made Beach Axle?
munki63
Epoxy is my duct tape
Canada
I want to make a beach cart, But I'm not entirely sure how to get the tires attached. Ive got bunch of tires that are off an Argo that I want to use. Pictures would be great as well, Thanks
munki63
Canada
I dont think that style of bushing will work with the tires I have, there is a two inch hole in the center of my rims and its a 5 bolt rim
munki63
Canada
make up some hubs and use a 5/8" rod for an axle.
Than you can buy plastic or nylon rollers at any boat store that work great as bearings.
Thats originally what I wanted to do, but I thought I had 4 bolt not 5 bolt, I had some flanges but they are 4 bolt
Any Ideas on making hubs?
Boris
The Good Old Days
just about anything will do for the hub. It's not like it's going to see high speed or great loads.
1/4" aluminum plate should be more than enough and easy to cut. Drill the center hole to 7/8" and use a lawn tractor plastic bushing as a slide.
munki63
Canada
So cut the plate for both sides of the rim, bolt them together, drill a hole in the middle for the tractor bushings, then use cotter pins to hold the tires in place?
do you have a picture/link for lawn tractor bushings?
Boris
The Good Old Days
One side of the rim should be sufficient and let me see if I can find a picture of the bushings.
You can use sections of PVC as a bushing as well.
