I have a Highroller Stunt fiberglass freestyle hull, with alum pole, Wamiltons steering, bars, throttle and trim, steering cable, trim cable, ignition switch, dual X Metal scuppers, carbon ride plate., motor mounts, 550 gas tank, water lines, exhaust tube, rule bilge pump, intake grate, mid shaft.
Has some scratches mainly on bottom. Surface paint crack around pole mount but no structural damage.
Darrell 734 386 6657 Michigan
